Alittle Help Picking out a new carb for a 460
Old Oct 20, 2007 | 01:10 PM
decatur5717's Avatar
I just bought a 1978 Ford Bronco from someone leaving town, I did a little research on it and found that the engine was replaced with a 7.5 460. Problem is whoever did the swap did not spend the right amount of money to do it properly and because of this I am running somewhere in the neighborhood of 200 horses. There is a lot of work that needs to be done on it for it to run the way I want it. I intend to make this truck strictly for track and off-road. Emissions don’t matter at all considering I don’t have to go through the process. First I want to start with replacing the stock cab (my guess came off the original 351) and manifold. Any suggestions?
Old Oct 20, 2007 | 01:54 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Re: Alittle Help Picking out a new carb for a 460
Hey and welcome to Thirdgen?
Why is it exactly that you are posting a question about a vehicle that is in no way related to a thirdgen chevy? You would have much more luck on a ford or bronco forum.
Old Oct 25, 2007 | 10:17 AM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
ummmmm............ If the 460 is a super low compression 1972+ model, which it most likely is, a 600 is probably enough since it will never see over 5000 rpms. I ran a 750 Edelbrock on a 10:1 429 and it ran excellent. The stock intake manifold is a decent piece and I would leave it alone unless you really want to change it.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
fasteddi
Sep 10, 2015 09:32 AM
90formulaVortec
Sep 3, 2015 09:26 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
