Restrictor Plates or 2 barrel
Old Oct 24, 2007 | 12:13 AM
SDIF's Avatar
Car: 91 Z/28, 89 RS Race Car
Engine: 305 stock / ZZ4 AFR 195 9.7:1
Transmission: T5 / t10 / Jerico
Axle/Gears: 10blt w 3.42, 9 in w /3.80 DL
Does anyone have any experience with restrictor plates or 2 barrel race carbs?
The reason that I ask is that i am planning on running my car in a lower class next year which will allow no more than 1 hp for every 9.5 lbs of total weight with driver. HP is measured at the rear wheels on a chassis dyno. ie. 3100lb car can not have over 326 rear wheel horsepower.
I do not know how much power I have now but would estimate 500 at the flywheel. 350 chevy, Button aluminum Flywheel on lightweight flex plate, 3 discs clutch, T-10, 9 inch ford. Last time car was weighted with driver was 3021lbs wet.
350 SBC .030 over , AFR 195 64 cc heads with mild hand port to enhance CNC porting, good valve job. JE Flat Tops, Zero deck height, .039 head gasket, heads milled by engine builder to give about 10.5+:1.00 CR.
Ring seal is tight as a drum. No blow by, Crank case well vented, etc
Cam is solid roller by BULLET. I don't know the specs did not want to know for fear of second guessing the experts. I asked for a cam that would not eat valve springs and would have good, smooth, predictable, linear power and survive a ham fisted driver who admits to missing a few shift from time to time. Very pleased with the cam. It pulls to 7000 shift point very quickly.
Rotating Assemble is 6 in rods and GM steel crank, Timing MSD 6al , unilite advance welded up, 36 deg all the time.
Intake is now Vic Jr with 750 dp.
Now the question... Will a restrictor plate or a 2 barrel 390 or 500 knock out a significant amount of power.
Also will the restrictor plate or smaller carb on this motor monkey with the fuel signal or other issues and not be a good idea for this combination.
Old Oct 24, 2007 | 12:43 AM
4playta's Avatar
Car: 1984 Trans Am
Engine: Built chevy 350
Transmission: TCI Built 700r4
Axle/Gears: 3.73 posi 10 bolt
Re: Restrictor Plates or 2 barrel
I would just retard the timing alittle and then bump it back up in the pits...lol!
Old Oct 24, 2007 | 08:11 AM
You could do what the drag racers do; use an adjustable, or even a controllable and variable, "throttle stop".
Old Oct 24, 2007 | 11:54 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
get it dyno'd and pull out 4 degrees of timing if needed and that should do it.
Old Oct 24, 2007 | 12:59 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
4 deg taken out of total timing is not doing to do it. W/ good heads on an SBC, which he has, you can run very little total timing and still make huge HP. You could run 28-30 deg w/ those heads it the motor would still be cranking along.
Old Oct 24, 2007 | 02:49 PM
xpndbl3's Avatar
Car: 1984 Z28
I'm sure pulling the timing out will drop HP considerably, on a bbc with AFRs, 2 degrees of timing was worth 50hp on a dyno. More restrictive exhaust, etc etc will drop power levels, but really I'd be thinking of adding a slight amount of ballast somewhere to help handling since you can't be much above the 350hp level at the rear wheels once you pull timing and maybe add a smaller exhaust.
Old Oct 24, 2007 | 06:18 PM
SDIF's Avatar
Sorry not to mention this earlier. Exhaust
Exhaust is 1 3/4 full length headers to 3 inch Dr. Gass Cross Over and then to Boom Tube.
"Louder than Marshall Stack"
Old Oct 25, 2007 | 02:04 PM
xpndbl3's Avatar
Car: 1984 Z28
weigh the car, see what you can get away with and then tune it on the dyno, that's the only way you'll get real world results. Anything else is pissing in the wind.
Hotrodboba400
Dec 10, 2019 07:07 PM
loud91rs
Oct 5, 2015 10:05 PM
ndndndnd
Sep 28, 2015 08:00 AM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
