jetting question
Old Nov 14, 2007 | 02:52 AM
dc_sniper9130's Avatar
Car: '84 Camaro SC
Engine: Swapping in a 305
Transmission: 700-R4
Axle/Gears: 3.23 One-Wheel Sqealer
jetting question
Alright, here's my deal. I picked up a mid-70s quadrajet at a swap meet for like 25 bucks, and am half-way through rebuilding it. I'm planning to run a 270/270 470/470 cam and 1.6 rockers, in a port/polished 305 with an edelbock performer air-gap, 1" phelonic spacer, and a hood scoop (for cold air). is there any way i can know before i put the thing back together and put it on the motor what size jets i should use? i know almost for certain they wont be stock, any ideas or suggestions?
thanks a bunch
Old Nov 14, 2007 | 09:30 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
What jets and rods does it have now?
Old Nov 14, 2007 | 02:24 PM
Car: '84 Camaro SC
Re: jetting question
I'm not sure. The jets in the kit are most likely stock but I don't know what size, and I don't think they included new rods in the kit, so those would be stock for sure. How would I tell? Do I measure them with a caliper or something?
Old Nov 14, 2007 | 02:58 PM
five7kid's Avatar
Jets and rods don't come in a rebuild kit. They assume you'll put the originals back in.
The jets are numbered. The rods are numbered with a letter. The secondary rods have two letters, and the secondary rods hanger has a letter stamped on it.
Might not hurt to have your carburetor number as well.
Old Nov 14, 2007 | 03:32 PM
Car: '84 Camaro SC
The secondary rods are a CH, the jets are a 9, the primary rod hanger has a 9 on it, and the primary rods have 48K on them. The secondary hanger has a K on it.
Old Nov 14, 2007 | 03:46 PM
five7kid's Avatar
The primary jets should be a 2-digit number. It's the jets and rods together that determine the jetting.
The K hanger is a fairly lean one. Going with a lower letter usually helps.
Old Nov 14, 2007 | 04:04 PM
Car: '84 Camaro SC
The second digit is horribly faint, but I'm going to say it looks the most like a 2. So the jet size would be a 92?
Also, if I were to get a jet kit, would I want the 1/4-32 or 6/32 size jets? And about the hanger, what would you recommend?
Old Nov 14, 2007 | 04:20 PM
five7kid's Avatar
You need quadrajet jets.
92 doesn't sound right. 76 maybe.
B hanger is pretty popular.
Old Nov 14, 2007 | 04:23 PM
Car: '84 Camaro SC
Oh, yeah, I could have been looking at them upside down. Right-side up would be with the numbers on top then. In that case it would be a 76.
colton_carlson
Mar 8, 2019 12:21 PM
fasteddi
Sep 2, 2015 10:29 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
