card swap time..
Old Nov 22, 2007 | 03:15 AM
fastfbody's Avatar
Car: 1989 GTA trans am
Engine: L98 350 tpi
Transmission: 700r4 built
Axle/Gears: 3.45 4th gen 10 bolt
card swap time..
i have a 1990 model irocz modds in sig . I was rolling around everything running great when a code poped up i found out is was a lose wire fixed it . on that im going to the far more familer carb set-up. i been needin more rpm the tpi doesnt cut it .heres what ill be slapping on just as a temp set-up till the big swap meet rolls around. performer intake with a 600cfm weber carb (always good cfm for a 350).i ran 12.9s before the swap any ideal what it will run with the extra air ?
also any tips on the need stuff for the swap .do tell
Old Nov 22, 2007 | 12:11 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
"600 CFM Weber carb"? Not sure exactly what that is. But, it's a little small. 650-750 would be more like it, and a double pumper would be the hot ticket along with a Performer RPM instead of a standard Performer intake.
Can't say for sure about times. I don't recognize that cam. Was anything done to the heads, or were they bolted on out of the box?
What gears are you running? Anything done to improve traction?
I assume this means you've given up on the Stealth Ram.
Old Nov 22, 2007 | 03:47 PM
fastfbody's Avatar
Engine: L98 350 tpi
Re: card swap time..
its a perfect size carb for a 350 (at least on my stuff).i ran my 350 in my truck (l48 300hp and 380ft.lbs stock)with a 750 changed to a 600 ran much more aggrsive . the intake and carb combo is a "temp" mainly cause it was free i would never buy such a run of the mill set-up. the heads are around $899 new the come with what u would expect 1.6 rockers 2.02 3 angle vaules blah blah blah.you can get the heads bare for cheap but i just wanted them ready to use.no other modds have been added the reason i think it would be faster is cause even a none rpm performer gets more air then a tpi and my cam makes power 3200-5800 so should be a bit faster.its not as much im giving up on the stealth ram as much im giving up on all fuel injetction.
Old Nov 22, 2007 | 04:34 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Probably an AFB clone. Weber makes the Performer for Edelbrock, and probably Carter now as well.
Old Nov 22, 2007 | 05:25 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
I think the carbs a little on the small side myself, but since you know its the perfect carb for any 350 out there I guess thats a moot point.. you will also need a non-cc dist.
Old Nov 22, 2007 | 11:22 PM
fastfbody's Avatar
Engine: L98 350 tpi
the weber is a Edelbrock so is the intake just fyi.
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
mustangman65_79
Aug 8, 2015 12:07 PM
