92 rs 305
Old Dec 6, 2007 | 12:55 PM
robster66's Avatar
Car: 1992 Chevrolet Camaro RS
Engine: 305 T.B.I.
Axle/Gears: 2.73 Open Diff
92 rs 305
I went to go look at a 92 305 rs and it's carbed They didn't make any 92 camaros carbed did they? He says it has 109k miles on it and the motor and tranny runs fine.
Old Dec 6, 2007 | 01:13 PM
Demon_Eater's Avatar
Car: 91 Camaro RS
Re: 92 rs 305
um...
and what are you asking about?
92's did have carb as I recall (who knows,I could be wrong too), but Im pretty sure 92 has a carb.
Old Dec 6, 2007 | 01:16 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The last carb on an f-body was in the 1987 model year.
A '92 RS, if V8, would have a Throttle Body Injection unit on it from the factory. The air cleaner looks like a carb air cleaner. The throttle body looks like a 2-bbl carb to the untrained eye.
It's probably a TBI.
Old Dec 6, 2007 | 08:49 PM
robster66's Avatar
Engine: 305 T.B.I.
Re: 92 rs 305
yea it does look like a carb air cleaner I didn't look at it that much
Old Dec 6, 2007 | 11:41 PM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
Re: 92 rs 305
92 Camaros did not come from the factory with carbs. I want to say 87 was the last year for factory carbs. Now in the last 15 years any possible mod could of been done. That car is probably a TBI. If the owner does not know the difference between a carb and a tbi I would check out everything he says about the car before I purchase it. Sounds like he didn't do his homework so maybe you should.
You can go to this link to see the production drive train info on the 92 Camaro: https://www.thirdgen.org/1992-chevy-camaro
Old Dec 7, 2007 | 05:33 AM
robster66's Avatar
Engine: 305 T.B.I.
Re: 92 rs 305
http://i21.photobucket.com/albums/b2...0/DSC00031.jpg
that is what I thought I would see on a 305 or 350 of this year.
Old Dec 7, 2007 | 05:50 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: 92 rs 305
That's what you see on a Z28 in 91 or 92. Not an RS. The RS has TBI.
The unit looks something like this:
Should have a big round air cleaner around it like a carb.
IF you want a fast car, look for a car with the system you linked. If you want a project car to make fast, get either, if you just want a car, get an RS.
pjsparts
Oct 29, 2025 06:39 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
rsrookie
Sep 5, 2015 07:08 PM
Formula_88AE
Sep 3, 2015 01:47 PM
