Q-jet... Nothing
Car: 1988 Camaro IROC
Axle/Gears: 3.27 9 bolt posi (non 1le)
Q-jet... Nothing
So I've got a engine from the 1970's with a Qjet on it. It's also got an electric choke.
The carb was rebuilt with the standard rebuild kit just new gaskets and such. I reinstalled the carb and now the engine just cranks doesn't try to start at all.
It's getting fuel, maybe even too much fuel. But just wondering if anyone had any ideas on where I should start troubleshooting.
The choke isn't hooked up to anything, and there are 3 hoses on the carb that are blocked off.
The ones that are hooked up are:
Fuel, Brake booster, one goes to the top of the valve cover, one goes back just under the dist.
There are two on the front that are blocked, and one on the back.
I know without pics its a hard shoot, but just wondering if anyone had any suggestions on where to start
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Q-jet... Nothing
How do you know it's getting fuel? When looking down the primary butterflies, and you rotate the throttle linkage, you can see a spurt of gas?
If so, then it's spark. Fuel is REALLY easy. As long as you can see it, the car should at least try to start. It'd chug and spurt and run for a few seconds then die (if there's a problem). But if it won't catch at all, it's spark.
Car: 86 Camaro Z28/ 87 Camaro IROC Z28
Engine: 5.0L TPI LB9 / 5.0 TPI LB9 w/cam
Transmission: Built 700R4 with Transgo shift kit
Axle/Gears: 3.27 9 bolt Posi/ 2.73 10 bolt Posi
Are you sure its getting gas?
Have you cracked open the door and looked inside while you press the throttle lever to see if the primaries or secondaries are actually squirting gas?
When carb cars sit for awhile they usually dont have the pressure to push gas through the system to fill up the fuel bowl.
If you see no gas squirting, then get an empty can and get some gas into it. Open up the secondaries and pour a good swig directly into the carb.
Now when you go to start it and the engine chugs along and dies, that means it burned whatever you put in and ran out of gas. Pour some more gas into the engine and pump it while you are starting it up. After awhile, you might have to really floor it but give the above the try first.
Damn sonix ... me slow multitasker, you beat me to the punch...
Chuck84TA
Carburetors
Jan 14, 2013 11:29 AM
RedRokkit
Feb 27, 2010 08:25 PM
