bogging down
Old Mar 23, 2009 | 07:08 PM
HarmonyCamaro's Avatar
Car: 83 Z28 Camaro
Transmission: 5 Speed manual
bogging down
i have a 305 and the carb is a Q-jet... my question is what causes it to bog down and how do you fix it?
Old Mar 23, 2009 | 08:24 PM
csmith3's Avatar
Car: 70T/A, 87Formula, 02Hawk, 06 GTO
Engine: 400, 350, LS1, LS2
Transmission: M21, 700r4, T56, 4L65-E
Axle/Gears: 3:55, 2:77, 3:45, 3:46
Re: bogging down
Based on the limited info you gave I will have to ask a few questions. What year is the car? Is it stock configuration or has it been mucked with? When does the bog happen? In my experience the CCC quadrajets are quite good and when they function correctly they are quite fun, they make a great sound when they open up. I just need to get an idea of what we're working with to be able to help out.
Old Mar 24, 2009 | 08:47 AM
Car: 83 Z28 Camaro
Re: bogging down
from what i know its a stock q-jet
my car is a 83 camaro
its good untill all four barrels open up then thats when it bogs down
and a little in the two barrel right before four open up... so another words when i put the pedal to the metal....
and i agree they sound nice when all four barrels open up i can take a picture of the top of the carb if you want to?
Old Mar 24, 2009 | 01:10 PM
csmith3's Avatar
Re: bogging down
Yeah, a picture would help out alot. Just need to verify a few things.
Old Mar 24, 2009 | 01:33 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
In the "welcome to the carb forum" sticky in the top section of this forum, and also linked from the thirdgen.org homepage, there is a tech article about getting the most out of your computer controlled q-jet. It describes the air valve system and how to adjust it. It doesn't talk enough about the choke pull-off ("vacuum break" in factory-speak), which is also involved with the AV system and avoiding bog upon opening those huge secondaries.
Read through that stuff, check to verify your choke pull-off is working properly, make the AV adjustments, and you'll be able to fix this problem.
Old Mar 24, 2009 | 06:02 PM
Car: 83 Z28 Camaro
Re: bogging down
ok csmith its little windy and cold at the moment so im going to hold off on the picture
Old Mar 24, 2009 | 09:45 PM
csmith3's Avatar
Re: bogging down
Understand, it gets nasty here in Oh too, but it is getting warmer here now. Been working on my nephew's 88 formula 305 tpi the last couple of days. But while you're waiting, the write-up that five7kid mentioned is very worth-while reading. The CCC q-jets are really not that difficult to get dialed in. I'll check back. BTW five7kid knows what he's talking about.
Old Mar 25, 2009 | 09:57 AM
Car: 83 Z28 Camaro
Re: bogging down
i should have some pictures for you after i get off work today around 6 central
pjsparts
Oct 29, 2025 06:39 PM
RedLeader289
May 28, 2019 01:47 PM
Infested
May 22, 2018 11:56 PM
Grant2k
Apr 4, 2016 08:21 AM
middian
Sep 5, 2015 01:42 AM
