air filter
Car: 06' chevy 1500 and 84' z28
Engine: 305 with an unknown cam and heads
Transmission: 700-r4
Axle/Gears: its an open rear 3.48 or 3.73?
air filter
I have a Edelbrock preformer intake and Edelbrock Avenager 600 CFM carb. I know I need a drop base Airfilter but I'm not sure what one. Jegs' tech people wern't much help. I just don't want to but the wrong one. thanks-Matt.
Re: air filter
I'm running a 14x3 K&N element with a Performer RPM intake (which is higher than a plain Performer), and running a 1.5" drop base without any clearance issues on a Camaro.
Looks like you are running a 305 which means you could stick with the stock element (12"x2.5"), and run a 0.5" drop base without any problems. If you want to go with a 14x3 element, then a 1" drop base would be safer.
Re: air filter
Thanks man, I bought the car with a 650 Holley dp. It was filled up with rust from the bad fuel tank. I replaced the tank, manifold(it was stock), and carb(new fuel lines, filter...ect). Not i just have to finish what i started. I have also have a few problems with getting the correct brackets for this combo but i think i have solved that.
Car: 91 RS Vert/98 Sierra9
Engine: 5.7/5.0
Transmission: 5spd/auto
Axle/Gears: 4th gen rear with 3.73
Re: air filter
I've heard that too much of a drop in the base will interfere with the carb any ideas? my carb is manual choke by the way Senior Member
Car: 1984 Trans Am
Engine: Built chevy 350
Transmission: TCI Built 700r4
Axle/Gears: 3.73 posi 10 bolt
Re: air filter
Transmission: 4L80E/4L80E
Re: air filter
Forgot about that...if you have a Edelbrock Performer carb, there might be clearance issues for the fuel inlet on the smaller 12" dia. drop base, but should be fine with the 14" unit.
FYI - I'm running a pre-1974 modified QJet carb without any clearance issues with the 1.5" drop base.
Engine: 5.7/5.0
Re: air filter
i have a 14" i believe I"m pretty sure my fliter is 14" but not 100% sure but i'll give that a shot thanx
1992 Trans Am
May 10, 2023 07:19 PM
Brinkkl2000
Aug 4, 2018 08:29 AM
