holley carb question
Car: 1989 RS camaro
Engine: 350Ci
Transmission: TH-350
A guy at work gave me 2 of his old holley carbs that need to be rebuilt, they look to be in good shape, but he didnt know what size carbs they are,.....are there any kind of numbers i.e. serial # where i can look what size they are if so.....where are the numbers and......where kind i find that info on the web......thanks
Car: 1989 RS camaro
Engine: 350Ci
Re: holley carb question
i was seeing if anyone had ever delt with the tech. support at holley i sent them the #'s on the airhorn to see what kind of carbs i had, if anyone has just seeing how long it takes to respond its been 24 hours already...
I also found something out, dont know if many people know about it but its a way to find what carb you need for your motor
Cubic Inches x Max RPM, then divide by 3456 = recomended carb CFM
Transmission: 4L80E/4L80E
The size formula is familiar here.
If you have the List numbers, you can get the information from Holley's website under Tech Service, Technical Library, and Carb Numerical Listing.
Car: 90RS Conv.
Engine: 383 w/ small shot
Transmission: th400
Axle/Gears: moser 9in
not to jack the thread, how accurate is that formula? You go by max rpm of the cam range?
It's accurate assuming 100% volumetric efficiency (pretty rare on a street engine) and a single plane intake manifold.
It basically gives you the minimum carb size for an expected RPM max.
Car: 90RS Conv.
Transmission: th400
Wow. I love this site, So much information to be learned. BUT.. now I have more questions.
Dialed_In
Aug 20, 2015 01:45 PM
86IROC112
Aug 17, 2015 02:00 PM
