Stripped Threads - Accelerator Pump Nozzles
Car: '84 K5 Blazer
Transmission: TH400
Axle/Gears: D60/14bolt 4.10:1
Well I managed to strip the threads out for my accelerator pump discharge nozzles.
What's the best way to fix this? I did some searching but most all the threads were about fixing the threads on the bowl screws.
FWIW, it's a Holley 670 Truck Avenger. I think it happened because the bowl vent crossover tube makes getting straight on the screw difficult and I ended up running the screw in at an angle.
Any help/ideas would be appreciated.
What's the best way to fix this? I did some searching but most all the threads were about fixing the threads on the bowl screws.FWIW, it's a Holley 670 Truck Avenger. I think it happened because the bowl vent crossover tube makes getting straight on the screw difficult and I ended up running the screw in at an angle.
Re: Stripped Threads - Accelerator Pump Nozzles
Same fix works for those as any other stripped threads....
Heli-Coil.
Heli-Coil.
evilstuie
Jan 9, 2020 08:29 PM
toronto formula
Nov 10, 2015 06:17 AM
