edelbrock 1406 rich in the secondaries
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
ok so i am running an edelbrock 1406 600cfm carb on my 350. the primaries are fine, but it is rich on the secondaries. i play with the throttle under the hood and when i open it up to the secondaries it spits fuel out of the top. like it is getting too much fuel. also some black smoke comes out from the exhaust. i don't know if i have the stock jets in there or not. it has been awhile since i looked. what would you guys recomend? buying a calibration kit and put the stock ones in? any help would be nice.
Re: edelbrock 1406 rich in the secondaries
Probably not a valid test. Snapping open the secondaries (with no accelerator pump on the secondary side) at idle with no load doesn't really similate what happens when you nail it in gear under load.
Secondaries in the Edlebrock only have jets- no rods (only has rods on the primary side, similar to a QJet).
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
without knowing which jets are in there, it would be hard to guess at one to replace it with. For all you know, it could be a smaller jet than stock, so by installing a stockjet you would be creating an even richer condition. If the take the jets out, they have numbers on them, 3 digits. With that you can grab a manual, or visit their website and figure out what you have and go from there
Car: 2000 BMW M5
Free revving is telling you nothing. The enrichment you'll get on the secondaries is for pulling under heavy load.
i will do what 86 said, pull them out and see what they are. on that carb you just have to remove the top plate right?
Car: 2000 BMW M5
Yes. You may end up ripping the paper top gasket, so order a kit and have it ready so you don't strand yourself. The gasket is super thin and tends to get torn taking the top plate off.
ok thanks, i am going to order those now.
Car: 1986 Camaro SC
Engine: Bolt-on/cam 305
Transmission: 700R4 w/ 2500stall
Axle/Gears: 3.73 10bolt Posi
For what its worth, I'd very much doubt the possiblity of the 1406 being too rich on the secondaries in stock tune. I went from stock .092 jet in the secondaries to a .101 with my mild 305, and its still on the lean side. Who knows whats been put in there, but with you're setup, stock jets are going to be very lean...
i will pull it open this weekend and see whats in there
Car: 1991 Camaro
Engine: Morris 434 Single Turbo
Transmission: TH350
Axle/Gears: 9" Ford w/4.11's
Get a Holley................ LOL J/K
I have not messed with edeljunk carbs since the 80's so I cannot tell you.
Pac J
May 17, 2020 10:44 AM
efiguy
Sep 27, 2015 01:30 PM
Night rider327
Sep 25, 2015 04:47 AM
1406, 62cc, black, cam, carburetor, edelbrock, heads, jet, opening, rich, secondaries, secondarys, smoke, squirting, test
