Carb Problem
Old Feb 8, 2008 | 09:45 PM
82Five-O's Avatar
Car: 82 Sport coupe
Engine: 355 semi roller
Transmission: TH-350 B&M ratchet shifter
Axle/Gears: 3.73 Eaton Posi
Carb Problem
I have an edelbrock 600 carb. If i crank the motor too long and it doesn't start, fuel pressure builds up in the bowls and it squirts fuel long after i quit cranking. What is wrong?
Old Feb 8, 2008 | 09:47 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Carb Problem
What does your fuel system consist of? Where is fuel squirting from?
Old Feb 9, 2008 | 04:04 AM
82Five-O's Avatar
Car: 82 Sport coupe
Re: Carb Problem
mechanical fuel pump, filter, edelbrock 600 carb
Old Feb 9, 2008 | 02:02 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Carb Problem
Is it a stock fuel pump? Where do you see fuel squirting from?
Old Feb 9, 2008 | 07:47 PM
82Five-O's Avatar
Car: 82 Sport coupe
Re: Carb Problem
it's coming out on top of the carb, everywhere. Why is my carb building this kind of pressure?
Old Feb 10, 2008 | 05:13 AM
comp's Avatar
Re: Carb Problem
sounds like hight float level and or leaking needle and seat maybe
Old Feb 10, 2008 | 05:25 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The carb doesn't build fuel pressure. The fuel pump gets fuel to the carb via pressure, but the fuel in the carb should be at atmospheric pressure. If it's coming out of the carb, it's because it is overflowing, which 9 times out of 10 is a problem with the needle/seat float valve continuing to allow fuel into the carb when it should be shutting off the fuel flow. As stated, dirt in the needle/seat is a common culprit.
Old Feb 15, 2008 | 08:30 AM
lukn4trbl's Avatar
Car: 2000 SS, M6
Engine: Modified LS1
Re: Carb Problem
The above is all true, but you may want to have a look at the fuel pump
pressure.
If the pressure at the needle/seat valve is more than about 9 PSI, the float
can be forced down and cause the needle to lift away from the seat.
Check that the fuel return line (if equipped) is not pinched.
Old Feb 15, 2008 | 10:38 AM
Damon's Avatar
Re: Carb Problem
BTW- Edlebrock's are notorious for not tolerating high fuel pressures. Most people say 5 PSI is about it before problems start. At 7 you're apparently just ASKING for trouble with them.
I don't use them much so I won't say I've got personal experience with it, but I've seen many people post problems similar to this over the years and my general take on things is they are more "touchy" about fuel pressure than other carbs- even QJets, which also can't take high fuel pressures.
Old Feb 15, 2008 | 11:05 AM
lukn4trbl's Avatar
Car: 2000 SS, M6
Re: Carb Problem
That's nuts. Most mechanical pumps are on the thin edge of providing that
pressure at idle. It's no wonder that most engine's I've tuned with Edelbrocks
have had rich idles.
Old Feb 16, 2008 | 06:33 PM
Hotrodrobert's Avatar
Re: Carb Problem
I have used a bunch of the Eddys and I have had problem with too much fuel pressure on most performance aftermarket pumps but very few problems with stock pumps. Your fuel control valves(needles and seats) are not controling the fuel flow. If they are clean and tight, you might try lowering the floats a little. If you take the top off the carb and invert it you can use a hand vacuum pump to put a vacuum on the inlet fitting. If it holds vacuum, the valves are working, if not you must fix the problem.
midge54
Dec 27, 2019 04:14 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
theurge
Aug 21, 2015 12:46 PM
