what's the best port to run the hvac
Old Mar 14, 2008 | 07:27 AM
REDTAIL's Avatar
Car: 86 iroc 92 rs parts car
Engine: 350 305
Transmission: t5 t5
Axle/Gears: 3:73, 3:08
here's the scoop. when I bought the iroc that i have now it was a engine swap from a 305 to a 350 plus it's got a ncc carb edle. 600 now the hvac isn't switching form window to vents to floor. I'm 99% sure it because the vacuum line isn't hooked up.I know I have the extra port on the carb but it's in the front and this spring I want to clean up the engine bay i.e.get rid of all the cut wires from the old cc system. so is there any other port I can tap to getting the controls working with out have to run it of the front of the carb.also hopefully I can up grade to a air gap intake and a Holley 650 dp this spring but the money hasn't really been pouring in lately.I feel comfortable with tuning carbs now thanks to the help from this board but too sure of the Holley bodies.So I'm not sure with the vacuum ports on the holleys but will need one port to run the dizzy.
Old Mar 14, 2008 | 10:32 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
You need full manifold vacuum. You can get that from the carb or tap off the manifold runner, but ported vacuum won't cut it.
Old Mar 14, 2008 | 10:43 AM
REDTAIL's Avatar
Engine: 350 305
Transmission: t5 t5
Re: what's the best port to run the hvac
k thanks, right now the intake I have has a spot that is blocked off probably about 1/2" hole +/- god only knows plus it's in the back so it's out of site which is what I'm looking for.Alright then does anyone know if the air gap intake has port that I can tap in to (probably go with summit's model)for vacuum
Old Mar 14, 2008 | 11:59 AM
pondriver's Avatar
Car: 1992 Camaro ZO3
Engine: 350 HSR
Axle/Gears: 9 bolt/3.70's
I'm running an air gap and it does have the port available.
Fast355
Dec 2, 2016 06:33 PM
Casey Meyers
Mar 2, 2016 10:46 AM
86White_T/A305
Aug 17, 2015 12:16 AM
Jake_92RS
Aug 11, 2015 10:39 AM
mx127
Aug 10, 2015 08:13 AM
