what year carb will direct fit a 1986 LG4?
Old Mar 18, 2008 | 01:17 PM
tarheel's Avatar
Car: Sold: 1986 Z28 Black/Silver
Engine: LG4
Transmission: 5 spd
so i got the car running well and then stripped the fuel lines thread that lead into the carb!
looking at replacing the carb from a used one on ebay.
What year camaro carbs are a direct fit on a 1986?
Car is totally stock.
Old Mar 18, 2008 | 01:32 PM
Re: what year carb will direct fit a 1986 LG4?
Ouch....
About 82-87. Ones from a Monte Carlo or a Caprice will also fit.
Old Mar 18, 2008 | 01:43 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Did you strip the fuel threads going into the fuel filter adapter, or from the fuel filter part into the carb itself?
ie. can you just replace the fuel filter socket part? If so, use the five finger discount at the local JY and just grab that part.
Old Mar 18, 2008 | 03:07 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
If you've stripped the threads in the carb body you can pick up a kit that self taps a new fitting into the body. I got one at NAPA a few years back for a few dollars. Just have to be extra careful not to allow any of the metal shavings to enter the float. You can do it on the motor but you'll have to block the fuel passage to the seat with a plugged vacuum hose or something, then blow everything out.
Old Mar 18, 2008 | 05:10 PM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
I had the same thing happen to me. I tried thread tape. And the self taping fitting someone just mentioned, But it still leaked with all. I finally gave up and got a holley reman q-jet. the cars never ran better
Old Mar 30, 2008 | 11:49 AM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
How much was that Holley reman Q-Jet and where did you get it from?
Old Mar 31, 2008 | 05:21 PM
onebad89RS's Avatar
Car: 89 RS
Engine: 305 carbed
Axle/Gears: 3.42 auburn posi
you can use any Q-jet from 82-87 like someone mentioned but with a $7 adapter plate you can put any square bore carb on I.E edelbrock, holley, demon. adapter plate is from edelbrock sold through jegs or summit.
Old Mar 31, 2008 | 05:33 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Originally Posted by onebad89RS
...with a $7 adapter plate you can put any square bore carb on I.E edelbrock, holley, demon. adapter plate is from edelbrock sold through jegs or summit.
Which, of course, would also require a non-computer distributor, TCC lock-up provision if automatic, and is about a 90% guarantee to be a downgrade.
Old Mar 31, 2008 | 07:53 PM
onebad89RS's Avatar
Car: 89 RS
Engine: 305 carbed
good point forgot bout that
Old Apr 27, 2008 | 02:07 AM
zed's Avatar
zed
Car: 1991 Z28, 1984 Z28, 1990 Toyota 4x4
Engine: L98, L69, 22RE
Transmission: 700R4, 700R4, 5Speed Manual
Axle/Gears: 3.73, 3.23 Posi, 4.10
if you still need one, i found a rebuilt carb for an LG4 in my garage, never been installed, could use a bit of cleaning, but it's all there, PM me with an offer if you want it.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
cstrobel65
Aug 15, 2015 10:19 AM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
matthew911
Aug 12, 2015 09:38 AM
