Jet starting point for 650 dp on 327
Old Apr 5, 2008 | 08:38 AM
einarak's Avatar
Car: Camaro RS
Engine: 327
Axle/Gears: Alloy axles, motive 3.73
Can anyone give me an idea of good jet size to start with in a Holley 650dp with proform main body, on a 327 10.2:1 8000 rpm engine. 6spd Manual t56, 3.73:1 rear in 89 Camaro. Jets #72 #84 came with the proform main body, but I think they are way to big.
Old Apr 5, 2008 | 06:27 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Start with 72/84 jets. Tune from there.
Old Apr 13, 2008 | 08:30 PM
z282slo's Avatar
Car: 91 z28
Re: Jet starting point for 650 dp on 327
My 650 DP that I upgraded with a Proform main body loves the 72/84 jets. The only changes I made from stock were the secondary high speed air bleeds, I went down two sizes. Have you tried it yet with those jets?
Old Apr 14, 2008 | 05:11 AM
einarak's Avatar
Car: Camaro RS
Engine: 327
No, I´m still waiting for my diff to be installed...
I´m new to carb building...
There were two #36 airbleed jets included with the main body, And it said on the package "use these in rear if your carb has two idle air screws". Mine has two idle air screws up front and none in the rear. Than I should use those smaller jets? Do some holleys have only one idle air screw or do the mean if it has screws on both front and rear?
Old Apr 14, 2008 | 03:11 PM
battyice's Avatar
Car: 1985 Z28
Engine: 355 topped with Dart heads
Axle/Gears: Stock axle with 3.73's
Some holleys have a "four corner idle" system, which has two screws on each metering block.
Based on your observation of no idle screws on the rear metering block, go with the #36 air bleeds.
Orr89RocZ
Apr 25, 2016 08:28 AM
fasteddi
Sep 2, 2015 10:29 AM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
onebadazzsrt
Aug 15, 2015 07:00 AM
