MCS Dwell question.
Old Apr 8, 2008 | 09:44 AM
alicat's Avatar
Car: 1985 z28 camaro
Engine: 305 lg4,edelbrock,3"air cleaner.k&n
Transmission: turbo 700r4 w/b&m megashifter
Axle/Gears: Stock.
MCS Dwell question.
I have my dwell set at 29,ranges slightly between 28.7 and 29.4.Idle mixture screws are 4 turns out,and idle speed is 850 and steady.When i rev the engine,the dwell reading decreases so the mcs is putting more fuel in?.So more dwell is leaner and less is richer,is this right?.Also is the dwell supposed to range
up and down very much,mine at idle stays pretty much on 29,unless i rev it.
Last question,if the plug that covers the lean stop screw,is'nt there,can it vibrate out of adjustment.
Alicat.
Old Apr 8, 2008 | 11:18 AM
Damon's Avatar
Re: MCS Dwell question.
The stock cover over the IAB screw is just there to prevent tampering, not to hold it in place. The screw has 2 o-rings on it further down that effectively hold it in place so it can't vibrate out of adjustment (that's not really their primary job, but that's what they do).
Dwell can and does change under various running conditions. No carb is going to give a perfect A/F ratio under all conditions so the ECM must constantly stay on top of things via the O2 to trim the mix. And a "snap throttle" test is a very big change in operating conditions in a very short period of time- there may even be special programming in the chip to temporarily ignore the O2 and do a certain set of changes to the dwell for a short period of time for all I know.
Actual running conditions on the road are the best for determining if things are set reasonably close (dwells within reasonable ranges). Blipping the throttle in the driveway or just revving it up under no load bears little resemblance to what is going on while driving out on the road.
Old Apr 16, 2008 | 03:06 AM
dirtywhiteZ28's Avatar
Car: 84' Z28-White/T-Tops
Engine: H code LG4 305
Transmission: TH700R4
Axle/Gears: Stock 3.23
The lean stop screw has enough tension from the spring underneath it to keep it in place usually, but with out that plug in place I would be concerned about debris entering the float bowl area, especially water if it rains. Or in your case sand and dust. The plug also would prevent excess fuel vapor from escaping the bowl area.
Old Apr 16, 2008 | 04:40 AM
alicat's Avatar
Axle/Gears: Stock.
After looking at the carb diagram,i realised that i was looking at the rich stop screw.The lean stop screw still has the plug over it.I can put a plug of silicone on the one thats missing.
Alicat.
ZZ3Astro
Aug 13, 2019 12:57 AM
fbodyfreakls1
Oct 6, 2015 06:34 PM
corey8084
Sep 17, 2015 02:56 PM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
Ian Irvine
Sep 4, 2015 08:08 AM
