So i searched for wiring help but nothing
What Wires should I keep when i switched from efi to carb? I know the typical power wires and all, but are there any wires fro my computer I should not remove? My vatts is already disarmed so no worries there.
Also anyone knowledgable on how to fix the tv cable?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Ignition, alternator, gages (temp, oil pressure), TCC lock-up.
You will need a TV corrector bracket. Which one you get depends upon what carb you get.
Re: So i searched for wiring help but nothing
Okay so all i have to do for the throttle cable is just get it tight right? then get the tv corrector and get that thing tight?
How will i know which one to get for a certain carb. I guess call the company direct?
Engine: LS1/LQ4
"Tight" isn't quite the word I'd use. "Adjusted" is more like it.
As to which corrector bracket, either summitracing.com or jegs.com, or as you said, the carb manufacturer.
Ghettobird52
12-29-2023 08:23 AM
