89 TPI TO CARB WIRING AGAIN-
Old Apr 24, 2008 | 06:05 PM
irocdaddy's Avatar
Car: 89 iroc,2012 eco 150,roadglide
Engine: zz4
Transmission: t56
YES I KNOW POSTED BILLIONS OF TIMES, BUT HAVE NOT SEEN THIS ANSWERED CORRECTLY.
3RD GEN 82'-86' ECM AND WIRING ON PASSENGER SIDE PULL OUT W/O NEEDING ANY OF THOSE WIRES FOR CARB SWAP EXCEPT ONE WOULD NEED TO WIRE THE FP,FANS.
3RD GEN 88'-92' IT SEEMS YOU DO NEED SOME WIRES FROM THE ECM TO STAY INTACT....
SO WHO DID THE SWAP ON AN 89? WHAT IS THE REAL STORY ON WHAT STAYS AND GOES FROM THE ECM WIRING GOING TO THE MOTOR AND ACCESSORIES?
IN 89' DID THEY WIRE A TPI LIKE AN 86'?
Old Sep 2, 2008 | 09:04 PM
SKYNOVERYA550's Avatar
Car: 88 iroc z28
Engine: 355
Transmission: Bowtie stg 3
Axle/Gears: 4:11
Re: 89 TPI TO CARB WIRING AGAIN-
looking for the same answer!
Old Sep 2, 2008 | 09:14 PM
igotta355z28's Avatar
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
Old Sep 2, 2008 | 10:13 PM
Car: 88 iroc z28
Engine: 355
Axle/Gears: 4:11
i got your reply on my phone, but came on and it was gone. wierd...
Old Sep 2, 2008 | 11:18 PM
Car: 1991 Z28 1LE
Transmission: 4l60e
i deleted what i wrote because it sounded retarded lol. im tired worn out from today when i get a few free minutes tommorow ill run down the wires i kept on my 89 for ya im sorry bout that but my spelling was horrible although it always is and my grammer and sentance structure was all messed up, made me sound like a retarded hillbilly and I didnt think it would sound very credible. but right now im only doing slightly better. so like i said tommorow ill right up something good for you and i hope it will help until then goodnight i have class way too early in the morning...
Old Sep 8, 2008 | 08:29 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
The wiring really depends on what you want. I have gone from TPI to carb at least 4 times now. Currently doing so yet again.
It IS possible to run the Dual fans with the ECM, but it is not reliable at all.
The simplest way is to wire the ground from the fan relay to utilize the stock fan switch. At a certain temp it will cut the fans on. Hypertech sells one for $40 that has a lower temp.
You can remove all the Injector wires, or save some for the sake of having spare ignition sources. The ECM controls the injector grounds not power. So power is always available.
The alternator is not controlled by the ECM. The ECM does get a reference voltage but that is about it.
You can snip all the following:
Knock sensor wire.
ESC wiring
MAF wiring
TPS
IAC
MAT
EGR
Distribtor wiring
AIR PUMP
Make sure you keep the Coil and tach wire intact, and buy the HEI connectors from jegs, so it clips in the distributor stock $10 for both
If you use the AC still everything will work.
If you need anymore help call me
Cale 251-209-1518
midge54
Dec 27, 2019 04:14 PM
Infested
May 22, 2018 11:56 PM
86IROC112
Aug 17, 2015 02:00 PM
stalkier
Aug 13, 2015 12:59 PM
Sanjay
Aug 12, 2015 03:41 PM
