Can I use -8an line?
Car: 1985 z28 camaro
Engine: 305 lg4,edelbrock,3"air cleaner.k&n
Transmission: turbo 700r4 w/b&m megashifter
Axle/Gears: Stock.
I have some fuel system bits ordered with summit,and they wont have any of the -6an hose,until early july.They have -8an,would this be to big,and cause any problems,or can i use it?.Looking at the ID sizes of both on a digital caliper,theres not a lot of difference.By the way this is their twist tite hose i'm getting.
Thank's,
Alicat.
Thank's,
Alicat.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Can I use -8an line?
Yea, no problems having a hose too big. As long as you can get the fittings to downsize to make it still connect to whatever you're connecting it to.
Axle/Gears: Stock.
Summits arrival date has changed to 21/5, so i'll leave it as -6an.Would have involved changing a few fittings,and having a few too many joins for my liking,but good to know i can use bigger line.
Thanks.
Thanks.
