650 mighty demon fuel bowls
Old May 15, 2008 | 07:28 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
This might be a stupid question but its bugging me. Are the fuels bowls suppose to keep fuel in them at all times or if the car sits for a couple days do they empty back into the fuel line because the lack of fuel pressure.
Old May 15, 2008 | 08:05 AM
lukn4trbl's Avatar
Car: 2000 SS, M6
Engine: Modified LS1
Re: 650 mighty demon fuel bowls
The fuel bowls should retain fuel when the engine is off and sitting for
long periods of time.
The fuel inlet located high up on the bowl and even if a little fuel went
back into the supply lines, there should still be some below the site level
plug.
Check the fuel bowl gaskets, or intake manifold plenum area for fuel pooling. You might have a leak.
Old May 15, 2008 | 02:26 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Could it be possible that the power valve is blown ?
Old May 15, 2008 | 04:54 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
plug.
Well i just got home and checked the carb. The fuel inlet is right in the middle of the sight glass. The fuel is right under the sight glass so if i rock the car a little bit you can see it slush around. So im guessing that the fuel is emtying back in to the fuel inlet since the bottom of it lines right up with the bottom of the sight glass.
Old May 15, 2008 | 10:00 PM
lukn4trbl's Avatar
Car: 2000 SS, M6
That's pretty much where the level should be.
The bowl will never be 100% full because the float will rise and close the
needle/seat valve.
From what I can tell your fuel settings are correct.
Street Lethal
Apr 30, 2019 12:14 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
beastin91rs
Oct 9, 2015 07:38 AM
New2Chevy
Oct 4, 2015 11:27 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
