Choke fuse keeps blowing
Old May 25, 2008 | 07:58 PM
magadith's Avatar
Car: 83 Trans-Am (Recarro)
Engine: 305 4bbl
Transmission: 5 speed manual
The fuse keeps blowing and the wires in the engine compartment to the choke are in good condition. I noticed it all started around the time I put a carb cleaner additive in my fuel. But for some reason I don't believe a fuel additive can blow a fuse. Any ideas?
Old May 26, 2008 | 01:04 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Check the entire choke heater circuit for a short somewhere.
Old May 26, 2008 | 10:59 AM
magadith's Avatar
Engine: 305 4bbl
Re: Choke fuse keeps blowing
I found behind the fuse box the wire was melted. But I cant tell if its melted deep behind the dash but the worst of it is behind the box. I am going to replace much of the wire as I can get to which is only about 5 inches but its the only exposed wire that I can see. Can this short melt the wire evenly?
Old May 26, 2008 | 04:07 PM
magadith's Avatar
Engine: 305 4bbl
Well i replaced as much of the melted wire as I can possibly could get to and its still shorting. To go any farther the dash my have to come out. I think this time its going to a professional. I just hate having to deal with the dash.
Old May 26, 2008 | 06:14 PM
Jaime-TA-84's Avatar
Car: 1984 Firebird Trans Am
Axle/Gears: 3.73 Posi
Check the choke heater relay.
Old May 29, 2008 | 12:13 AM
magadith's Avatar
Engine: 305 4bbl
Stupid question but where is the relay located at. The Haynes wiring diagram doesn't even show the C-H circuit.
Old May 29, 2008 | 12:32 AM
In my car it's covered by the drivers side bottom dash panel (behind the ALDL connector). Theres a flip-down thing similar to the fuse panel that flips down and has the C-H relay, convenience buzzer, and turn signal blinker.
3rd gen money
Oct 11, 2019 09:57 PM
thunder57
Nov 7, 2015 02:28 PM
Fanatic1074
Oct 2, 2015 03:47 PM
lanceflame44
Sep 25, 2015 12:28 PM
90formulaVortec
Sep 3, 2015 09:26 AM
