700 cfm Q-Jet too much for LG4???
Old Jun 3, 2008 | 05:04 PM
Josh R's Avatar
Car: Iroc
Engine: 350 4-bolt
Transmission: T5 non-W/C
Axle/Gears: 3.27 Open
So i keep reading about how if you want some easy performance without ripping out your computer you can just tune the Q-Jet. I also read that there good carbs for mild performance. I have a 1986 Iroc with the Lg4. I put flowtech shorties on it and 2.5in all the way back (no cat, dynomax cat-back). I also ripped the A.I.R system out. It says in tech articles that our carbs can do from 750-800 cfm just by making the secondary air-valve open all the way. And i have read various places to then put a G hanger and CK (or something close) rods on it. Will this 700 cfm setup be too much for an LG4?
Old Jun 3, 2008 | 05:26 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
No, because when the AV tension is properly adjusted to prevent bog, the AV will only open as much as the engine can use.
69GTOby
Apr 18, 2016 02:34 PM
okfoz
Oct 13, 2015 02:19 PM
Dragonsys
Sep 25, 2015 03:51 PM
Third_Gens_Rule
Sep 3, 2015 06:56 PM
Third_Gens_Rule
Sep 3, 2015 06:55 PM
