Fuel problems is it the sock?
Old Jun 26, 2008 | 04:08 PM
LordTTK's Avatar
Car: Camaro Z28 -84
Engine: Weiand 144, 350 CSB
Transmission: B&W T-5
Hello, i have a fuel problem with my -84 Camaro its a 350 engine with a Weiand 144 blower and non cc quadrajet.
I use a mechanical fuel pump piston style that is capable to 50 PSI.
but all the time that i go out and drive around, the fuel pressure will drop and the fuel delivery will quit.
It can happen when I'm driving at cruising speed or when i stand still...
And to get the fuel back i have to blow air into the line that goes back to the tank from the coal canister or what its name is
I have one fuel filter in the carb and one filter just before the fuel pump.
When everything is working nice and i open the fuel tank i hear a psyyyy sound.
And when the fuel pressure drops and the fuel delivery will quit and if i open the fuel tank cap i hear no sound.
should there be all the time some kind of a pressure in the fuel tank?
And i got one tip that i should drop the tank and check how bad the sock on the pickup looks and remove the sock totally.....
So before i go and drop the tank does anyone here have any idea what the problem could be??
Please just ask if i forgot to write something.
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
