Just finished Enigine swap and I'm having trouble with the Carb
Old Jul 7, 2008 | 08:44 PM
RazorN8's Avatar
Car: 1987 camaro
Engine: 383 AFR heads
Axle/Gears: Ford 9" 3.70:1
I just swapped out my LG4 for a 350 from a work van. The Electric choke decided to quit on me during the swap (I think). Theres the lttle lever by the choke with an E on it. It never goes fully open. The choke never fully closes either. There doesn't seem to be as much spring pressure slapping the choke plate closed when I open the throttle. I jerry rigged a spring on the bottom of the carb to close the plates when I first start to get me by for now. Do you think that My problem is in the electric choke? What should I look for? I have an older quadrajet that I might be able to use if I can figure out how to plumb hot air into the choke mechanism.
I also don't have my O2 sensor in my exhaust because I used headers that don't have a port. Is that something I need to work on or can I leave it? I know it sets the mixture, but I'm really burned out on this car right now.
Old Jul 7, 2008 | 08:50 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Just finished Enigine swap and I'm having trouble with the Carb
You're using the LG4 carb and choke wiring?
Old Jul 7, 2008 | 08:54 PM
RazorN8's Avatar
Car: 1987 camaro
yes
Old Jul 7, 2008 | 08:58 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
What's your choke light doing? When is it on and when is it off?
Old Jul 7, 2008 | 09:06 PM
RazorN8's Avatar
Car: 1987 camaro
I know that it is on most of the time that the car is running. it might be off when I first start the car. I'll go check a minute>
Old Jul 7, 2008 | 09:07 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Check your alternator connections. The choke light needs to be on when the engine is off, and off when the engine is running.
Old Jul 7, 2008 | 09:08 PM
RazorN8's Avatar
Car: 1987 camaro
its always on. when the car is off it's on as well
Old Jul 7, 2008 | 09:11 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Are you using the LG4 alternator as well, or did you swap a different one in?
Old Jul 7, 2008 | 09:12 PM
RazorN8's Avatar
Car: 1987 camaro
everything is LG4 except the motor. Intake manifold is summit non-EGR and headman tork step headers. I had to modify the throttle cable bracket to work with the intake manifold as well. That is causing me some problems with shifting I think.
Old Jul 7, 2008 | 09:14 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Check your alternator wiring and connections then.
Old Jul 7, 2008 | 09:20 PM
RazorN8's Avatar
Car: 1987 camaro
Voltage readings seem normal, maybe even high. As far as I can remember all of the wiring to the alternator seemed fine. Why would the alternator affect my choke? When I first start the car, the choke plate swings most of the way open like nothing is holding it back. I can't see how the alternator would affect that.
Old Jul 7, 2008 | 09:22 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
If the alternator isn't charging, the choke relay won't apply power to the choke coil, and the choke light will stay on all the time.
Old Jul 7, 2008 | 09:25 PM
RazorN8's Avatar
Car: 1987 camaro
Th alternator is charging. Is there some kind of spring in the electric choke thermostat thing to close the choke. On the other quadrajet I have, the choke seems to be spring loaded.
Old Jul 8, 2008 | 11:20 AM
RazorN8's Avatar
Car: 1987 camaro
ideas?
Old Jul 8, 2008 | 06:17 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The electric choke is a spring. It's a bi-metal thermostat heated by passing an electric current through it. The warmer it gets, the less the spring pressure and the choke butterfly opens.
Old Jul 8, 2008 | 07:37 PM
RazorN8's Avatar
Car: 1987 camaro
what do you think are the odds that that is the problem? Should I take it apart and check it out? The car is currently at the transmission shop because i los 2nd and 4th gear. I wasn't getting any good answers here and I was getting burned out on working on the car. I'll pay someone else to tackle that problem. When I get it back I will drill out the rivets and take the electric choke apart.
Old Jul 8, 2008 | 07:42 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The choke coil may be working properly, depending on what ambient temperatures are like where you live right now.
You have an electrical problem if your choke light doesn't go out when the car starts.
Old Jul 9, 2008 | 08:33 AM
RazorN8's Avatar
Car: 1987 camaro
I have a bunch of electrical problems right now. I'll look into it when I get a chance.
midge54
Dec 27, 2019 04:14 PM
Cleotiz
Jan 6, 2018 08:56 PM
midge54
Jan 29, 2017 07:00 PM
theurge
Aug 21, 2015 12:46 PM
jharrison5
Aug 19, 2015 05:53 PM
