Mr gasket clear fuel filter install question
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
I picked up a clear glass fuel filter for my t/a , was wondering if I remove the filter that is in the q-jet or keep them both? I planned on putting the new one inbetween where I cut my fuel line for my former edelbrock install. I have since swapped back to the q-jet.
thanks
thanks
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Mr gasket clear fuel filter install question
Yea, you pull the one in the q-jet. Just make sure you leave the white plastic ring in there, that's what seals the threads there. (it'll probably be stuck in the carb body, and you'll never know what i'm talking about...)
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Transmission: 4L80E/4L80E
If it's plastic, don't install it. A while back a member posted pictures of what was left of his car after the fire department left. Clear plastic fuel filter burst and sprayed the hot engine with gasoline.
Car: 1990 Camaro
Transmission: 4L60
Yes they can and will catch fire..Working at a parts store we have been
getting away from all the plastic and 100 % of those Mr.Gasket Plastic ones
are recalled replaced by solid glass type...
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
I remember that. The piece of mind alone is worth the extra $5 for a steel one from edelbrock or the like.
Car: 88 GTA "Cocaine"
Engine: 350 tpi
I had a glass one break
what do you need to see the fuel for anyway
want to watch you $4+ on it way
Car: 1986 IROC
Engine: 355" TPI
I would get rid of that thing. They are a disaster waiting to happen. The stock filter is a good design and will work well in most applications.
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
i'd replace the stocker myself.
1992 Trans Am
May 10, 2023 07:19 PM
