rethinking plug temp
Old Jul 11, 2008 | 05:14 PM
scooter500's Avatar
Car: 87 Camaro Z-28
Engine: 305 LG4 w/ E4ME carb
maybe I've been old schooling it too much. I have been using delco plugs rated one heat range up (correct gap). My thinking being that this will ensure best burn. However, another post got me thinking. Have I just been making things hard for my carb and/or engine by using too hot a spark range? what you think about spark plug heat ranges?
Old Jul 11, 2008 | 05:17 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: rethinking plug temp
The plug temperature has nothing to do with how well it makes the mixture burn, it's how easily the plug conducts heat away from its tip. If the plug is too cold, it will conduct too much heat away so that the tip won't get hot enough to burn off deposits, and the plug will foul. If the plug is too hot, it won't conduct enough heat away, and the plug tip will heat up and become a glow plug causing preignition.
db057
Apr 28, 2019 07:45 AM
86IROC112
Sep 11, 2015 04:04 PM
Jlanz55
Sep 9, 2015 09:09 AM
89 formula TPI
Sep 7, 2015 11:06 AM
85Special
Sep 3, 2015 04:21 PM
