Old quadrajet missing parts
Old Jul 17, 2008 | 06:39 PM
yevgenievich's Avatar
Car: numerous
Engine: ls1, others
Transmission: t56, others
Axle/Gears: 3.23 7.6"
I have a carb that is missing some linkages and i am not sure if i can buy the pieces somewhere or would i better off getting a new carb. I think it's missing linkage to the secondery. It says that it's quadrajet on the side, not sure which one
here are some pics:
Old Jul 17, 2008 | 07:26 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Old quadrajet missing parts
This is on your '67 Camaro isn't it? tsk tsk man, wrong forum!
Yea, you're missing the secondary air valve rod. Should be easy enough to grab at a JY. That carb desperately needs a rebuild...
Oh, the rod only keeps you from using the secondaries when the car is cold, so if you aren't a goofball driver (driving your COLD CAR hard) you'd never notice it's gone.
Old Jul 17, 2008 | 09:19 PM
Car: numerous
Engine: ls1, others
Thanks for info. I know there a lot of knowledgeable people here and it is carb forum. As far as i know i might be swapping it into my bird.
Old Jul 21, 2008 | 01:11 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Enough people put older q-jets on their 3rd gens that I don't see a problem with the chassis it's currently installed in.
You're missing the choke pull-off, or "vacuum break" in GM-speak. It has a link to the secondary AV, as Sonix stated. You'll have cold over-choking problems, and the possible bog going WOT when warm.
The secondary lock-out linkage is part of the throttle body, not the AV. The high-idle cam disengages the lock-out when it drops down with the choke fully open.
Old Jul 22, 2008 | 07:47 AM
Car: numerous
Engine: ls1, others
Thanks for info, i found this little piece and i think it might be the link to the secondary, i haven't tried to fit it in yet tho.
Infested
May 22, 2018 11:56 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
