gas coming out vent tube on hard take off.
Old Aug 2, 2008 | 12:59 PM
intex1982's Avatar
Car: 89 formula/00 z28
Engine: carbed 350/ls1
Transmission: 700r4/ a4
Axle/Gears: 3.23 posi/ 3.73 posi
gas coming out vent tude on hard take off and keeps coming out down the track. what is making this happen?
Old Aug 2, 2008 | 03:12 PM
69-er's Avatar
Re: gas coming out vent tube on hard take off.
I wonder if the fuel level is too high in the fuel bowl.
Larry
Old Aug 2, 2008 | 05:22 PM
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
lower your floats.what kind of carb u running?
Old Aug 3, 2008 | 10:28 AM
intex1982's Avatar
holley 4779-3 750dp psi set at 6.5
Old Aug 3, 2008 | 04:22 PM
try lowering your float levels
Old Aug 4, 2008 | 02:41 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You don't have fuel coming out under any other conditions?
Rather than just lowering the float level, you should make sure it is set right. It should just dribble out of the bottom of the bowl site plug hole.
Old Aug 4, 2008 | 06:38 PM
intex1982's Avatar
just on hard take offs. and it just dribbles out when u bump fender. and i even set psi down to 3psi to see if it still done it and it did well i would say it is more like blowing out of the vent tube on front side.
and get wrose when u let off the gas on hard acc
1992 Trans Am
May 10, 2023 07:19 PM
86White_T/A305
Aug 17, 2015 12:16 AM
mizz0313
Aug 12, 2015 06:45 AM
