Need help making the right pick of a carb
Old Aug 2, 2008 | 04:41 PM
RandyZ's Avatar
Car: 1983 & 1993 camaro z28
Engine: 5.0 carbed/ LT1 injected
Transmission: T5/auto
Axle/Gears: 373/posi
well i have a 305 ,5 speed 470 lift cam,323 in the rear ??? looking to buy a car carb.I have a few to pick from a carter spead bore or go with a vac sec 600cfm holley or holley 650 cfm dp mech sec.I have owned a 650 mech sec and had no prob but that was on a 350.Don't really know
Old Aug 2, 2008 | 05:19 PM
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
Re: Need help making the right pick of a carb
go with a 550-600 cfm carb.........and if you have a manual transe try to get a mechanical secondaries carb.......tho ive ran a similar setup yrs ago with a 600 cfm vac secondaries carb with no issues.just had to tune the secondaries by changing the spring
Old Aug 2, 2008 | 05:25 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Go for the 650 DP.
What Carter spreadbore are you looking at? Carter hasn't made a spreadbore carb since the Thermoquad stopped production in 1985.
Old Aug 2, 2008 | 05:28 PM
if you use the 650 you will have to re jet it for the 305.plus you will have to lean it out as well.........why over carb a small engine????????
Old Aug 2, 2008 | 05:30 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You have to re-jet any carb for any engine to get the most out of it. A 650 isn't such a terrible stretch for a 305.
Old Aug 2, 2008 | 05:52 PM
very true but why not start with something that is close to what he needs
Old Aug 2, 2008 | 07:38 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
There aren't many suitable performance DPs that come much smaller than 600-650 CFM. Smaller carbs tend to be VS designs for fuel economy, or DPs for dual carb NA and blower setups.
Old Aug 2, 2008 | 08:05 PM
RandyZ's Avatar
well i found a 650 dp ms for $50.00 i think its a score for the price in pretty good cond ,but i also fount a 600 vs in almost mint for $30.00 what would be the better one i am borrowing a holley 600 vs from some one i know for now but i don't really feel the sec ??? it worked perfect on his motor he says i just don't like the feeling is this the way the work i had all ms in my motor but they were all 350s
Old Aug 2, 2008 | 08:09 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You shouldn't ever feel the secondaries if a carb is tuned properly. Either of those would work, the DP would be preferred. Expect any used carb to need a rebuild.
Old Aug 2, 2008 | 11:46 PM
Bowtiebruiser's Avatar
Car: 1982 Camaro Z-28
Engine: 350 4bbl
Transmission: Borg Warner Super T-10
Axle/Gears: Richmond 10 bolt 4:10 Posi
Old Aug 3, 2008 | 09:52 AM
RandyZ's Avatar
Yea i think im going with the double pumper and just mod the jets in the back so when flooring it im not over carbing it.
Old Aug 3, 2008 | 04:24 PM
the 650 is a good choice specially with the price being so low...please go thru the carb and also try these jets 62/70 or 63/71 should be good for what u need
Old Aug 4, 2008 | 09:00 PM
RandyZ's Avatar
Well not to take the conv some where ealse but the reason for switching carb is because my Qjet started acting funny but i think i found the fix ??? Do any of you know if my Qjet shold read the same vac reading as a holly would ? I'm geting 16 from the holly and only 14 1/2 from the Qjet
theshackle
Sep 17, 2020 08:26 AM
midge54
Dec 27, 2019 04:14 PM
Below Average J
Members Camaros
23
Nov 18, 2015 10:03 PM
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
matthew911
Aug 12, 2015 09:38 AM
