Holley Carb...Hole in Main body?
Old Aug 4, 2008 | 10:48 AM
ereninger's Avatar
Hello,
I have been chasing a problem with a Holley Carb and from what we found...(rich condition on plugs and carb) the carb was actually getting black on the back side)
I think it is the power valve but when I pulled it out it looked pretty good and the rubber part was not broken....after looking closer it looks as if there is a slight hole in the actual main body of the carb where the power valve would go into...i can not remember if this was like this when i first got the carb or this is some sort of wear...basically i looks like a flaw in the cast of it...this hole is in the impression of front of the plate of the main body....does this sound like a problem or is this a flaw that has no effect?
THank you.
Old Aug 4, 2008 | 03:12 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The holes in the main body provide manifold vacuum to the power valve to close it. When manifold vacuum drops, the power valve opens.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
