Carb Problems
Old Aug 14, 2008 | 03:22 PM
yaretheytaken's Avatar
Car: 92 RS
Engine: 350 Carb'd (almost TPI)
Transmission: 700R4 (soon a T-5)
Axle/Gears: 3.23's
Carb Problems
I have what I believe is a carb issue. I have a 92 Camaro with a 350 4bbl Edlebrock 750 cfm. The main problem is that the first time I start the car each day whether it is in the morning or afternoon, no matter what temperature it is outside it never wants to start. I will pump the pedal a few times before attempting to start. Then I will crank it for 5-10 seconds stop and repeat until it starts. It usually takes about 1- 1 1/2 minutes to get it started. Problem number two is that once it does start it runs very rough for a while. For example if I try to accelerate it will just fall on its face, then I let off the gas and get back on it will go. This will happen at either part or full throttle. That problem seems to occur mostly when my car is first started, whether it is the first time of the day or any time after that it has problems going from a stop. If you want to know anything else about the car just let me know, any advice is appreciated. Thanks for the help.
Old Aug 14, 2008 | 03:48 PM
jpeden31's Avatar
Car: 1984 z-28
Engine: 305H.O. L69
Axle/Gears: 3.73 G80 GT4
Re: Carb Problems
check the timing, if its lookin good then check your coil
do you notice any kind of color of smoke when it does start up and runs rough?
Old Aug 14, 2008 | 05:33 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Carb Problems
Which Edelbrock 750 do you have, and how did you set up the choke?
Old Aug 15, 2008 | 07:44 AM
Car: 92 RS
Axle/Gears: 3.23's
Re: Carb Problems
I don't think I ever did set up the choke. I'm not even sure how to set up the choke. I'm pretty much a noob when it comes to carbs so, how would I go about doing that. As for what kind of carb it is I'm not sure I could find out but I'm at work right now.
Old Aug 15, 2008 | 07:55 AM
TransAm_85's Avatar
Car: 1985 Trans Am
Engine: built 355
Transmission: th350
Axle/Gears: Borg warner 3.08's
Re: Carb Problems
Make sure you check all of your vacuum hoses.
midge54
Dec 27, 2019 04:14 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
theurge
Aug 21, 2015 12:46 PM
