ccc problem
Old Aug 16, 2008 | 01:28 AM
Tightenloop's Avatar
Car: Camaro LT
Transmission: 700r-4
ccc problem
Hi,
I have got problem. I realy dont understand what's going on.
I have rebuild my 305 everythink was good, engine ran strong until I srewed on air filter on a top of carb. Since I did it, my engine stalls immidiatly after startup,the smoke smels extremely reach, I looked in intake manifold throu secondaries there was a lot of gas. I tryed remove airfilter and few times attempted to start engine (also after "flood clear procedure"), but promlem remains.
What should I do??
my Camaro engine spec:
chevy 305, rochester ccc carb (just after rebuild) comp carms xe264 hyd/rlr. all new valvetrain, ported and cleaned stock heads, full lenght hedders.
stock ignition. e3 spark plugs, Carter 120 gph fuel pump initial timing 10 deg BTDC
Old Aug 16, 2008 | 11:25 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: ccc problem
The air cleaner may be interfering with the linkage in some way. Make sure your choke is operating properly and the electric wire to the choke coil did not come loose.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
