Running strange after changing plugs and wires
Transmission: 4L80E/4L80E
First guess would be you got a couple of wires mixed up.
Did you drop any of the spark plugs?
Are all of the terminals properly installed on the wires? Are all of the terminals properly connected to the distributor cap and/or spark plugs?
Car: 1987 Camaro
Engine: 5.7
Re: Running strange after changing plugs and wires
That is apparently what was wrong. I went and got a few new plugs thinking I dropped one and caused it to go bad, well I started with number 3 then started the car, not the problem, then I took out number 1, The gap was way to close and I assumed that was the problem, switched plugs, started car and it sounded its old self again and is running strong. So all is good. I plan on checking the rest later to on on the safe side. Thanks for the help.
fearthisinc
Oct 25, 2008 09:18 PM
breathment
Oct 24, 2002 10:12 PM
