ccc quad av valve adjusting screw
Car: 1984 camaro
Engine: 305 l69
Axle/Gears: 3:08
guys im new and yes this has been outlined in tuning ccccarbs for performance but i must be blind cause i cant find the screw to set the AV tension can someone please post a pic of where it is on the carb i looked for 30 min. and no luck. sry for bringin this up as i stated but i just bought a 1984 l69 opt. camaro with the 700r4 with 78,000 original miles from the original owner and i would love to adjust the av's for more power! Thx guys!!!!!
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: ccc quad av valve adjusting screw
https://webdisk.ucalgary.ca/~jmknopp...ac%20port2.jpg
See the purple arrow? See how it's over a green rod? Follow that green rod back, where it does a 90* turn up, is where the screw is. It's tricky to get to. Right behind that bend is where you put the flat blade screwdriver. Remember you need to loosen the set screw first, allen key, directly below...
86CamaroDan
Sep 29, 2015 10:08 PM
New2Chevy
Sep 28, 2015 12:35 AM
