would like to swap TBI to Carburator. TIPs?
Car: 91 RS T-top
Axle/Gears: 3:42 fourth gen disk brake
I have a 91 camaro rs 305 tbi and im tired of the vaccum and electronic BS. I want to swap to a carburetor. I guess to get rid of the vaccum i would have to change the manifold also (NOT SURE). Mind you I dont have the best budget and this will be a daily driver until next spring. Thanks
Car: 89 Firebird
Engine: 408
Axle/Gears: 12 bolt/4.11
Re: would like to swap TBI to Carburator. TIPs?
This link should answer most all your questions.
https://www.thirdgen.org/forums/carb...rd-please.html
Car: 88 iroc z28
Engine: 355
Transmission: Bowtie stg 3
Axle/Gears: 4:11
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
If you want to keep the factory fuel pump in the tank you can use the billet fuel pressure regulator from Jegs. It will hold 20 psi inlet pressure and works great.
Car: 91 RS T-top
hell yeah I want to keep the factory fuel pump one less thing to do thanks for the info guys
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
a decent option would be a nice Q-Jet if you can find a manifold for one (spread bore) That carb when tuned right will knock down nice MPG numbers with good throttle response
Hello, Michael
Aug 20, 2015 03:19 PM
