87 305 problems PLEASE HELP
Old Aug 28, 2008 | 12:49 PM
the chief's Avatar
ok i have switched everything needed to go from tbi to carb. but im having some issues here they are maybe someone could help
1.its been almost imposible to time the engine i try to go by the tab and when i think its running the best im at really low RPMs on the tach. i have heard that i deling is suppost to be at arround 8k mine is arround 5k
* im running a accel dizzy by the way it came on my 80 305 sbc
2. motor shakes alot and feels like it strugles to go at first, i have a fuel pressure gauge on the line and they needle just bounces non stop.
i have heard that on 87 and up wit center bolt heads if you witch to carb you must fun hi octane gas like 92 oct is this right? i usually out 87 oct could the gas be causing this problem?
and if i want to change the heads to older style non center bolt what do i have to replace other than the heads them selfs
thanks in advance
Old Aug 28, 2008 | 12:56 PM
CJG1987's Avatar
Car: 1983 Trans Am
Engine: 305 4bbl
Axle/Gears: 10 Bolt 3.27 posi
Re: 87 305 problems PLEASE HELP
well i just did the same swap on my 83. did you swap to a non computer controlled carb and leave the ecm plugged in?
Old Aug 28, 2008 | 01:23 PM
the chief's Avatar
i put a edelbrock 600cfm manual choke
Old Aug 28, 2008 | 01:57 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
'87 TBI? Are you sure about that? TBI wasn't introduced until 1988.
No, you don't need to change to 92 octane because you put a carb on an EFI engine. Pure poppycock.
What fuel pressure are you observing? Did you put in a return-style regulator?
8k and 5k what while setting the timing? Are you disconnecting the vacuum advance when you set the timing?
Old Aug 28, 2008 | 02:29 PM
the chief's Avatar
its tpi, there is no regulator the line come straight out the pump to the carb on the carb line there is a fuel pressure gauge, and i tryed timming it wit the vac adc disconected and wit it connected, ive also heard that it could be the distribuitor?
Old Aug 28, 2008 | 06:14 PM
five7kid's Avatar
If you are running the stock electric in-tank fuel pump, you need a return-style regulator to drop the pressure going to the carb.
If you are not running the stock electric in-tank fuel pump, you need to remove it. There is a sticky in the top section of this forum detailing how to turn an in-tank electric pump pick-up into a mechanical style pick-up.
Does the Accel distributor have vacuum and centrifugal advance?
Old Aug 28, 2008 | 07:37 PM
the chief's Avatar
i know it has a vacumm advance but im not sure about centrifugal advance, how can you tell?
Old Aug 28, 2008 | 10:07 PM
five7kid's Avatar
If it has vacuum advance, it has centrifugal advance (also know as "mechanical" advance). The advance weights & springs are (usually) under the rotor.
Old Aug 28, 2008 | 10:26 PM
the chief's Avatar
so yes it thoes, so wat should i do?
Old Aug 28, 2008 | 10:36 PM
five7kid's Avatar
Set the timing at idle with the vacuum advance disconnected and plugged to about 12 degrees BTDC.
Still waiting to hear about the fuel pump.
Old Aug 28, 2008 | 11:46 PM
the chief's Avatar
the fuel pump is a mechanical one and im running a fuel cell in the trunk
Old Sep 1, 2008 | 09:50 AM
the chief's Avatar
bump
jhawkeye
May 25, 2022 06:33 PM
Jake_92RS
Jan 28, 2020 10:37 PM
theurge
Aug 21, 2015 12:46 PM
