th350 kickdown linkage
Old Sep 7, 2008 | 02:52 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
At the moment this is the only picture of my carb I have available. I may be able to grab another photo of the carb on the car if need be. Im having a hard time visualizing how the kickdown cable needs to be connected to work properly.
From what I understand, when the linkage is at WOT the cable should be pulled (extended). My problem is that there is no forward motion in the linkage. At the pivot point everything is moving towards the firewall opposite the direction the cable needs to be pulled.
Does my carb not have provisions? Is there a simple bolt on bracket available? Would more photos be helpful?
Old Sep 8, 2008 | 05:51 AM
Damon's Avatar
Re: th350 kickdown linkage
Yeah, it goes on the underside of the throttle arm and yours probably doesn't have provisions for it (I have a DP with the exact same type of throttle arm- and it's a very old carb if it's got that kind of throttle arm/secondary linkage).
They make a bolt-on piece that will give you a location for the kickdown stud. I think Holley makes it, but I can't remember- picked it up several years ago when I put the carb on my buddy's car that used a TH350).
Old Sep 8, 2008 | 10:26 AM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
any chance this is the correct bracket?
The catalog at the parts store didnt give me much to go on. Just (kickdown bracket for older holley double pumpers). I found it odd that edelbrock makes that part...
Old Sep 9, 2008 | 05:43 AM
Damon's Avatar
Yeah, that looks like the one I used.
Old Sep 9, 2008 | 02:13 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
thanks, I'll update this once it arrives.
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
mfp189
Sep 27, 2015 09:25 AM
romcjr
Sep 17, 2015 05:18 PM
89newfun
Sep 16, 2015 09:28 AM
383cam
Sep 9, 2015 06:01 AM
