CCC Q-Jet Secondaries Not Opening
Old Sep 10, 2008 | 09:07 PM
r0nin89's Avatar
Car: 1987 Chevy Stepside
Engine: 350 TBI w/ a Cam
Transmission: 3 Speed Stick w/ granny low
Now I may be mistaken here but if someone could guide me in the right direction it would be appreciated. This is my first carb'ed car all my others were TBI so I'm trying to diagnoss what I think is a problem.
When I push the throttle linkage all the way back the choke ontop of the secondaries does not open. Isnt the vacuum diaphram suppose to pull this open in order to feed the secondary barrels of the carb air?
When you turn the car on the diaphram just pushes out. No mater how much gas you give it, it doesnt come back in. WOT the choke is still close over the secondaries.
Where should I start to fix this? Diaphram? Or is there something I can adjust. Can anyone basically explain how its SUPPOSE to work?
Old Sep 10, 2008 | 09:14 PM
TexasSilhouette's Avatar
Car: 1991 TransAm GTA 350
Engine: 350 SBC TPI
Re: CCC Q-Jet Secondaries Not Opening
On a Q-Jet, the flap over the secondaries is the venturi. Air flow through the secondaries causes them to open. The vacuum motor makes sure they close and do not open too quickly.
If you push them open with the engine off, you can see the throttle plates. Opening the throttle all the way should open the throttle plate but only if the choke is warmed up or you hold the stop away from the throttle shaft. The carb is designed to prevent the secondaries from opening unless the engine is warm.
Old Sep 10, 2008 | 09:16 PM
r0nin89's Avatar
Ah ok I knew I had to be over looking something. I'll check them tomorrow then.
Old Sep 10, 2008 | 09:24 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The flap over the secondaries is the secondary air valve.
Old Sep 10, 2008 | 09:33 PM
r0nin89's Avatar
Is there a way to tune it for better throttle response?
Old Sep 10, 2008 | 09:39 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You can adjust the spring tension as described in the Qjet tech article.
Old Sep 10, 2008 | 09:42 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
https://www.thirdgen.org/quadrajet
69GTOby
Apr 18, 2016 02:34 PM
sreZ28
Oct 22, 2015 08:21 AM
racereese
Oct 10, 2015 09:39 PM
RedLeader289
Sep 23, 2015 06:50 AM
gta892000
Sep 16, 2015 12:37 AM
