bad fuel pressure regulator, or pump?
Old Oct 7, 2008 | 04:02 PM
85ZzZ4's Avatar
Car: 2005 Chevy Colorado/ 1985 Z28
Engine: fast burn zz4
Transmission: th350
Axle/Gears: 10 bolt (has to go) 3:23 gears
i am currently running a holley blue pump and holley fuel pressure regulator. the regulator worked fine for about a month, then one day at the track the car started flooding, i checked my fuel pressure guage and sure enough it was pegged at like 14 or something, so i turned the regulator down and as the car idled the guage went right back up... long story short, i bought a new one and it does the same thing... is there any way the fuel pump is bad and pushing too much fuel?!??
Old Oct 7, 2008 | 04:03 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: bad fuel pressure regulator, or pump?
Is the return line blocked?
Old Oct 7, 2008 | 04:54 PM
drfrankenstein's Avatar
iv got that same setup, there isnt a return line. its not a bypass regulator. well atleast thats how mine is.
Old Oct 7, 2008 | 07:45 PM
85ZzZ4's Avatar
Transmission: th350
no return line in this set-up... can't figure it out, i'm gonna try my buddy's spare pump and see if it makes a difference, but the pump and original regulator are only a month old... i'm lost...
MustangBeater20
Oct 29, 2022 09:20 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
89-S-dime
Aug 12, 2015 11:57 AM
Kaweh
Aug 9, 2015 02:54 PM
