Holley Internal Leak
Old Oct 20, 2008 | 05:44 PM
Davemutt's Avatar
I recently installed a Holley Avenger that had been rebuilt then sat in the box for about a year (bad, I know). It ran great when I first installed it but after a few weeks it was running poorly. I checked the float level and adjusted the mixture screws for highest vacume and idle. The problem now is the idle won't go below 875. I can adjust the idle speed screw, but the idle doesn't drop.
I pulled the carb and fuel is leaking from the front barrels. I replaced the power valve thinking this was the obvious culprit, but I have the same problem.
Anything I should look at, or do I need to do a complete rebuild?
Old Oct 20, 2008 | 06:09 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: Holley Internal Leak
Originally Posted by Davemutt
The problem now is the idle won't go below 875. I can adjust the idle speed screw, but the idle doesn't drop. I pulled the carb and fuel is leaking from the front barrels....
Sounds like too high of a float level. Setting it can be a little tricky, are you using the site plugs to determine the level? You'll want fuel to slightly trickle out of the site plug with the engine running....
cowansauto
Apr 3, 2025 12:51 PM
F.I. 57 Belair
Aug 23, 2021 01:09 AM
86CamaroDan
Sep 29, 2015 10:08 PM
Magman
Sep 14, 2015 01:30 AM
scottmoyer
Sep 7, 2015 07:06 PM
