Hey guys which wire do i send +12 to on the oil pressure sender switch to prime the motr. Swapped motor out his weekend and I cannot figure out where the ecm send it to prime when switch is on. Thanks in advance.
The fuel pump doesn't prime through the oil pressure switch.
great! what am i going to do now! Could I hotwire it to ignition switch somehow?
or could i run +12 to the relay somewhere to run it? I need to get the car home from my buddys house right now. I plan on putting it on an oil pressure sender later
You can just short the switch out temporarily.
cool, which wires do i need to short to get her going? the end two?
Pins D and C, should be a tan wire with a white stripe and an orange wire.
thanks man! I can short the wires and it will continually run until i disconnect them correct? I dont have the factory oil pressure sender on the car...
Yes
