87 intake/carb choice
Old Nov 19, 2008 | 09:46 PM
BJSX23IROC's Avatar
Car: 87' IROCZ-Z28
Engine: 350 T.P.I Bolt-ons
Axle/Gears: 3.73 posi
I have had a TPI 350 for four years now and want to switch finally to a carb. The problem is i have never been around carbed engines ever always stuck with EFI. SO my question is what is the best intake manifold/ carb for my car. The engine is stock minus edlebrock headers. New block. I want to put the carb sytem on first and then sometime in the future not sure how long (probably a little while) want to install a cam then maybe head work. So after all that basically i want to know what is the best setup that will allow for me to do this. I also would love it if I did not have to change from my stock hood. Mostly because i have an expensive paint job because of fleck... and i dont have the money to buy a new hood. Any suggestions would help and if there is no other options than to buy a new hood i guess i will just have to... just delays the project and i hate waiting haha. P.s. this is my daily driver car and intereseted in making it a fast street car that does not totally kill me with MPG
---sorry that was such a long post.
Old Nov 19, 2008 | 10:31 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I know this is the Carburetor forum, but it you want a fast daily driver with good fuel economy that fits under a stock hood, consider this http://store.summitracing.com/partde...5&autoview=sku .
Add up what it'll cost you just to convert to carb, and this will be both the short- and long-term less expensive route.
Old Nov 19, 2008 | 10:42 PM
BJSX23IROC's Avatar
Car: 87' IROCZ-Z28
Re: 87 intake/carb choice
yea i really want to et away from the EFI though. Thanks for the help but i mean as long as i am getting around 12 mpg i will be fine.
Old Nov 19, 2008 | 11:02 PM
BJSX23IROC's Avatar
Car: 87' IROCZ-Z28
Ok lets say i did do this HSR conversion... Are there noticeable hp gains or is it a waste of money and i should just stick with my stock TPI setup? sorry for this not being carb related.
Old Nov 19, 2008 | 11:46 PM
whitedevilTA's Avatar
Car: 1986 Trans am
Engine: 5.3 LM7
Transmission: T56 6 speed
Axle/Gears: Dana 44 w/ 3.55's
I would say on a stock 350 TPI, you'll def see a pretty big gain. Especially if you have supporting mods like headers and exhaust. I believe it's something like 30 horse over the TPI set up.
Old Nov 20, 2008 | 12:14 AM
BJSX23IROC's Avatar
Car: 87' IROCZ-Z28
is there also more that can be done to it and how hard to install
Old Nov 20, 2008 | 11:08 AM
five7kid's Avatar
No more difficult than a conversion to carb. Since you have an '87, PROM tuning wouldn't be a necessity.
But, as stated, other mods such as cam and exhaust would make it work even better. You should be able to do much better than 12 MPG.
Old Nov 24, 2008 | 05:20 PM
84'B.A.T.A.'s Avatar
Car: 88 Iroc-Z
Engine: 388 HSR
Axle/Gears: 9 Bolt 3.70
if you want to go to a carburated setup that will fit under the hood, go with an edlebrock performer style intake the rpm performer is a better higher rpm manifold but you will want a cam to use the higher rpm power it will be a bit boggier before you have your cam but then you wont have to buy to different manifolds. as for a carb for a stock 350 you want a 650 cfm carb prefferably a holley dp at a minimum, but demons are MUCH better!!
Old Nov 25, 2008 | 11:14 AM
five7kid's Avatar
With all of the reported BG quality problems of late, I don't think I would make that statement, especially not the "MUCH" part.
gixxer92
May 18, 2017 11:20 AM
Fronzizzle
Feb 9, 2017 09:31 AM
gmoutdoorsman
Oct 3, 2015 11:42 PM
david068513
Sep 18, 2015 10:36 AM
ericjon262
Sep 11, 2015 06:07 PM
