Manual Choke for Edelbrock?
Car: 86 Firebird
I bought my 1406 carb rebuilt, but it doesn't have a choke. I want to install a manual choke, but I can't find a kit for this. All I find is an electric choke conversion.
Does anyone know where I can find what I need to install a manual choke?
Thanks in advance!
Thanks in advance!
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Manual Choke for Edelbrock?
You don't need anything, just remove the electric choke and linkage, and plug the vacuum port.
Car: 86 Firebird
Are you saying I don't need a choke at all? I don't know much about carbs, but mine never had a choke of any kind (at least since I've had it). Will the carb function without a choke?
Engine: 383 Carb
Transmission: 4L60
No, to operate the choke manually you only need to take the electric parts off.
Car: 86 Firebird
Not trying to beat a dead horse, the only thing is there was never an electric component to remove, so I think I may be missing some basic parts. Here's a pic of the carb. Is there supposed to be a rod that goes in the circled area? Also, is that rod all I would need for a manual choke to work?
If anyone has any pics of a "complete" edelbrock, that would be great, too.
Car: 79 Trans Am Y84
Engine: Future LS2 6.0
Transmission: Future T56
I have the same problem. my idea was to somehow set up a manual choke and run it though the firewall and have a lever inside the car. i think we have to recreate the linkage the works the thottle but just on the other side. on the passange side top lever
Car: 86 Firebird
That's what I was thinking too, but Apeiron's post confused me a little. It seems to say there doesn't need to be a linkage or anything. I need a little moe clarification...I am a carb moron...
Car: 86 Camaro
Just go to the parts store and buy a choke cable and a choke cable mounting bracket. You run it to the choke lever. When you pull the cable it closes it when you push it in it opens the choke back up.
Dan
Dan
Car: 88 Iroc-Z
Engine: 388 HSR
Axle/Gears: 9 Bolt 3.70
exactly the same thing that i was going to reccomend, but your carb never came with a choke so you willl have to buy the choke "flap" also if you know what im talking about
Car: 88 Iroc-Z
Engine: 388 HSR
i apologize i was thinking of the wrong thing, you only need to pick up a universal choke cable kit at almost any auto parts store.
Hotrodboba400
Dec 10, 2019 07:07 PM
codeysabatini
Nov 10, 2015 04:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
