chip versus carb mods?
Car: -88 TA GTA
Engine: 350 tpi
Transmission: TH700
So, I have a Trans Am -85 lg4 305. It has a freeflowing exhaust, mild cam crane 114112(still an improvement over stock..) and a dual snorkle setup from a l69. Now I want to either mod the carb to resemble a l69 carb or get an aftermarketchip that makes timing and fuel-curve more aggresive....
My question: Should I stick with getting a good aftermarket chip for an lg4 ( like jet J2018511S), or should I also do changes to the carb?
Hasse
Hasse
Transmission: 4L80E/4L80E
There isn't that much to do to the carb beyond secondary rods & hanger.
You probably won't see much difference with a chip, but I'm not familiar with what a Jet chip does for you, either.
Car: -88 TA GTA
Engine: 350 tpi
Transmission: TH700
Re: chip versus carb mods?
Actually what Im looking for from a chip, is adjusted timing. Thats the main reason I want one. Dont know if I want stage 1 or 2 though.....
Regarding the carb I just thought that tehe chip and secondary rod/hanger mods would achive the same effects and that doing both would be overkill..
Car: 2004 GMC 2500HD
Engine: Duramax LLY
Transmission: Allison
It sure is. That's why you disconnect the ECM connector before setting the timing.
L69's had knock sensor, as did the higher compression LG4's from '85-'87.
Not really. More like you need to do both in order to achieve max benefits from either.
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
My 84 L69 has a knock sensor, though I'm not sure how much the timing is actually controlled by the computer, though I know it is. It's got to be one of the most primitive computers ever put in a car.
GeneralIesrussi
Sep 3, 2015 03:23 AM
