4-hole or Open hole carb gaskets??
Old Dec 17, 2008 | 11:58 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
I am running a 4-hole 1/2" spacer on my RPM Air-Gap. Would it be best to use a 4-hole or open hole gasket underneath the spacer? This is a 1/4" gasket to clear my booster fitting.
Old Dec 17, 2008 | 12:29 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Re: 4-hole or Open hole carb gaskets??
You should just get a 1" spacer and call it a day.Use and open gasket on the top and the bottom and your done.
Old Dec 17, 2008 | 12:31 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Hood clearance.
Old Dec 17, 2008 | 12:40 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
What are you doing with the threaded hole on the runner on the passenger side in the rear? Thats where you should plug you booster into. Then plug the pcv into the back of the carb.
Old Dec 17, 2008 | 01:37 PM
Jammin'Trey's Avatar
I wouldnt, then your only getting vacuum from one cylender. I had a problem with my brakes feeling hard. When I swapped the fitting from amnifold to carb there was a good improvement. I am not sure what carb you have but normally theres a big PCV fitting in the front.. Then normally a vac. advance fitting or 2 somewhere.
Old Dec 17, 2008 | 01:49 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Tha tapped hole in the back of intake isnt just taking vaccum of one runner its off the whole intake. And If he has a demon like in his sig the pcv needs to be hooked to the back of the carb.
Old Dec 17, 2008 | 09:20 PM
Damon's Avatar
Use the open gasket. You don't want the unsupported areas of a 4-hole gasket sagging and flopping around underneath the spacer.
Old Dec 17, 2008 | 09:35 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
90* Fitting for the booster. PCV is in the rear of the carb.
Demon's have one 3/8" fitting for PCV or booster in the rear and two smaller fittings (one ported or timed and one direct) on the passenger side.
Will do. Thanks
Old Dec 17, 2008 | 11:00 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
pcv should go to intake and the carb should have the booster if the vacuum fitting is only in 1 runner of the intake
Old Dec 18, 2008 | 09:09 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
There was a discussion about doing that and we figured it could lean out the #8 cylinder since the PCV is a constant vacuum loss while the booster is sealed.
Now it is brought up the booster still might not give full braking assistance due to only pulling vacuum from one cylinder, I don't think this would be as much the case.
Old Dec 18, 2008 | 09:47 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I added a 4-hole 1/2 inch phenolic spacer to cool my carb. I used a 4-hole gasket on top and a open on the bottom. The carb is cooler now.
I swapped from a Holley 3310 750vs carb to a Holley 750 Street HP. The Street HP has the fitting in back for the brake booster and another large port in front for the PCV.
oh yeah, I am running the RPM Airgap also. All under a stock 92 Z hood.
Old Dec 28, 2008 | 08:07 PM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
could always use the 4 hole gasket and just gasket match the spacer. or turn the 4 hole into a single hole spacer (cut out the cross in the center and blend it).
Old Dec 28, 2008 | 08:08 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Other way around.
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
lakeffect2
Aug 23, 2015 08:44 AM
BurlyChev
Aug 22, 2015 01:52 PM
