Tach Help
Car: 1991 Trans Am
Engine: 305tbi to 350 carb'd
Axle/Gears: Stock
Tach Help
can anybody help me with some info to help me hook up a 5" racing auto meter tach with a carbureted engine a step by step if the coil is in the distributor or if the coil is outside the distributor any help would be appreciated.
Car: 1987 Camaro
Engine: Oldsmobile 455
Transmission: Th-700r-4
Re: Tach Help
Well, it the Coil is inside the dizzy then there should be a prong to hook the tach wire to. I believe there are 3 prongs one of them is for the tach. And the coil is outside of the dizzy. Then hook the wire to one of the post on the coil I don't know which one. But there are plenty of online instrution for hooking up to a outside coil. Red wire is hot with key on, White wire hooks to the lighting on the dimmer/ I got my hook with the power wire, Black wire goes to ground, And I think Autometer is purple goes to Coil/ Ingition box if installed. Autogage is green wire which is same has purple.
Transmission: 4L80E/4L80E
Coil in cap: Connect the sensor wire to the "TACH" terminal.
External coil: Connect the sensor wire to the "-" terminal.
