Fuel pressure puzzler
Old Jan 2, 2009 | 11:21 AM
82Five-O's Avatar
Car: 82 Sport coupe
Engine: 355 semi roller
Transmission: TH-350 B&M ratchet shifter
Axle/Gears: 3.73 Eaton Posi
I have a strange issue with my holly carb. If i run the fuel pressure thru my regulator anything over 2 psi, the engine will run extremely rich. it will even flood out and die at idle. At 2 psi it runs great even tho the reccommended psi is 5-7. any ideas?
Old Jan 2, 2009 | 10:10 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Bad gage.
Old Jan 3, 2009 | 07:06 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: Fuel pressure puzzler
The carb could have an internal leak that stays sealed at lower pressure.
Old Jan 3, 2009 | 07:25 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Possible, but not especially likely. Fuel in the carb is only under pressure behind the needle.
Old Jan 5, 2009 | 09:45 AM
82Five-O's Avatar
Car: 82 Sport coupe
well i know its not a bad gauge because the reading on the gauge coincides with the setting on my regulator.
Old Jan 5, 2009 | 12:54 PM
five7kid's Avatar
Do you have 2 gages?
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
