Throttle cable too short!!!
Old Jan 15, 2009 | 07:50 PM
rodrob1961's Avatar
Car: 2003 SILVERADO /86 IROC/85 S10
Hey guys, I swapped my cfi for an edelbrock intake and carb. Ordered a new throttle cable and it is about 1/4 inch too short. Now what do I do? I refuse to grind on the $50 throttle cable bracket. Any and all help is appreciated.
Thanks,
Rod
Old Jan 15, 2009 | 08:02 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Throttle cable too short!!!
You can't pull it out until it reaches?
Old Jan 18, 2009 | 07:14 PM
rodrob1961's Avatar
I pulled it until it stopped and it is about 1/8 inch too short.
Old Feb 17, 2009 | 10:41 AM
Ford2transam's Avatar
Car: 1983 Trans Am ALL STOCK which is go
Engine: 305low
Axle/Gears: stock
1/8th of an inch.. Shoot Just bend the bracket some, A bench vice and a pair of pliers shoul work. Just make sure you are not at an akward angle and rubbing the cable.
Matt
Old Feb 17, 2009 | 07:29 PM
rodrob1961's Avatar
Thanks guys. I went ahead and installed it as-is and I think I can adjust the idle with the mixture screws and not have to fuss too much with the idle screw.
TheTraut88
Sep 11, 2015 05:16 AM
64goatman
Sep 9, 2015 01:09 PM
GouldyGTR
Sep 7, 2015 09:05 PM
TheTraut88
Sep 7, 2015 05:22 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
