replacing accelerator pump and tps seals
Old Jan 23, 2009 | 11:29 PM
dirtpoor1's Avatar
Car: 84 z28
Engine: 305 vin H
Transmission: auto
when I pulled the old retaining washers and seals out, a couple of the retaining tabs or staking that holds the flat washer broke off. I ended up grinding the others off in order to get new washer to seat down low enough. But how do I hold/retain them in place now that the staking is gone? Do I have to take a punch and peen the housing to hold the washers?
Old Jan 23, 2009 | 11:38 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
There are staking punches out there. I use a center punch.
Old Jan 26, 2009 | 03:46 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: replacing accelerator pump and tps seals
It doesn't take much for the soft aluminum. A small screwdriver with a gentle tap will work.
92camaroJoe
Jul 29, 2023 07:57 PM
jklein337
Sep 19, 2018 06:23 PM
perZ
Aug 15, 2015 01:17 PM
92camaroJoe
Aug 13, 2015 06:07 AM
