Varajet II ditch/keep??
Old Jan 24, 2009 | 12:04 AM
MikeSmith0890's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 2.8L, hopefully upgrading..
Transmission: BorgWarner T5, Made here in Muncie
Axle/Gears: stock
I have a 2.8L with the Rochester Varajet II... Is this carb any good or is there a replacement carb thats better? The carb doesn't seem to be performing too well and i was debating rebuilding vs buying.. any help is appreciated.. thanks in advance
Old Jan 26, 2009 | 01:47 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I don't know of any replacement for it unless you go non-CC and put a small 4-bbl on it.
The only one I had was on an '80 Citation 2.8. The car had about 250k miles on it when the body fell apart around the engine (miles estimated, because the speedometer quit after about 230k miles). I rebuilt the carb once, it always seemed to work well. But, that was a non-computer version.
Old Jan 26, 2009 | 02:23 PM
Axle/Gears: stock
Re: Varajet II ditch/keep??
thanks for the help. main reason behind me asking is i'm planning on doing the 3.4 swap and didnt know if i could get a better carb to run on the 3.4.
thanks again
i know holley makes a 350cfm 2bbl as does Demon Carbs but i dont know if that would be the correct size
Old Jan 26, 2009 | 03:13 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
As long as its a 2.8 leave the vara jet alone. The carb is not the reason that 60 deg V6 runs like it does.
Old Jan 26, 2009 | 05:19 PM
five7kid's Avatar
I took a quick look on summitracing.com for intake manifolds. Basically the only thing offered is a base upon which you need to put one of two uppers, a 2 bbl or 4 bbl. The 2 bbl is made for the Varajet, the 4 bbl for a standard squarebore Holley. About $200+ to get two pieces you'd need.
I agree the 2.8 isn't that big of a powerhouse. But, again, I didn't have any particular issues with the non-computer version of the Varajet.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
aaron7
Carburetors
Jul 7, 2015 06:28 AM
SoSoFresh_SS
Carburetors
Jul 19, 2008 01:49 PM
ericknight
Apr 16, 2008 11:49 PM
locomoshun
May 5, 2007 08:03 AM
